Line shared by analog phones from gate
I'm looking for product solving my following problem:
I need solve connectiong 2 analog phones to VOIP network so that both share the same line (both rings together, both can be used to talk in the same call). It's replacement of current analog solution.
I find PAP2T as gateway with 2 analog ports but not sure it supports my requirements. If not which product is appropriate or do you suggest another solution?
Thanks for help
sabah1000 Wed, 07/21/2010 - 08:04
Whats wrong with connecting two telephone sets to one VOIP port through a simple telephone splitter?!!!
Otherwise, you can have each port register with a unique extension number and then configure the "follow me" feature of your IP-PBX system so that when a call is received on one extension it would ring the other as well.
Related Content
