CallManager 4.x MGCP compatibility with 2900/3900 ISR G2 routers
Answered Question
Jul 21st, 2010
Hello All,
Is there a way to configure the new ISR G2 routers as an MGCP gateway under CallManager 4.x (specifically 4.2(3))?  There are no options for the 2900 or 3900 models available for selection.  Many thanks in advance for any assistance provided.
Correct Answer by Jaime Valencia about 6 years 5 months ago
The MGCP packets are formatted in a special way for each model, most likely they're quite similar for those models.
I'm glad it works, but bear in mind we still need to look at the Cisco support policies so that's not something we can provide support if you run into problems.
In my experience, usually customers don't like the phrase "might work but we won't support you" and with a doc that explains compatibility they always go for the upgrade.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Correct Answer by Jaime Valencia about 6 years 6 months ago
No, there is no way. You need to upgrade.
Either to 6.1(5), 7.1(3) or 8.
The only other option is to use H323, no way using MGCP.
java
Overall Rating: 5 (2 ratings)
beavisthrare1 Fri, 08/06/2010 - 06:24
Fellow Networkers,
A followup to the original issue.  Just for the sake of trying, I configured an MGCP gateway as a 2851 for the 2921 and it worked flawlessly.  I guess the key is to make sure you use the exact port number for your mods.  Thanks again for the assistance.
beavisthrare1 Fri, 08/06/2010 - 06:29
Thanks for the documentation, Java.  I will use it to convince the customer they need to upgrade.  Have a great day!
Correct Answer
Jaime Valencia Fri, 08/06/2010 - 06:37
java
