can't access WAP's web page but can telnet
Answered Question
Jul 21st, 2010
Can someone tell me why the following configuration won't let me access the web page of this WAP?
version 12.2
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname EwingWAP
logging buffered informational
enable secret 5 $1$z9vV$M.rY40womPNf7YPOQqC8T/
username careone privilege 15 secret 5 $1$nFXA$ezjkiBAHeboaKYMzB4hpq/
clock timezone EST -5
clock summer-time EDT recurring 2 Sun Mar 2:00 1 Sun Nov 2:00
ip subnet-zero
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid tsunami
    authentication open
    guest-mode
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
rts threshold 2312
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 172.18.86.5 255.255.255.0
no ip route-cache
ip default-gateway 172.18.86.1
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag/ivor
y/1100
ip radius source-interface BVI1
bridge 1 route ip
line con 0
line vty 0 4
login local
line vty 5 15
login local
ntp clock-period 2860650
ntp server 208.90.144.53
end
Correct Answer by Surendra BG about 6 years 6 months ago
Hi Jason,
Have you tried the default username and password??
Username - Cisco
Password - Cisco
Please try the below commands and let me know how this works out..
en
conf t
aaa new-model
ip http authentication local
end
Try opening the WEB GUI using the configured username and password..
Surendra
Overall Rating: 5 (1 ratings)
Surendra BG Sat, 07/24/2010 - 09:14
  • Cisco Employee,
Plz provide the output "sh ip int br" and "sh version"
Surendra
jasonww04 Wed, 07/28/2010 - 07:09
Here are the two outputs, as requested:
EwingWAP#sh ip int b
Interface                  IP-Address      OK? Method Status                Protocol
Dot11Radio0                unassigned      YES TFTP   up                    up
FastEthernet0              unassigned      YES NVRAM  up                    up
BVI1                       172.18.86.5     YES NVRAM  up                    up
Virtual-Dot11Radio0        unassigned      YES TFTP   down                  down
EwingWAP#sh ver
IOS (tm) C1200 Software (C1200-K9W7-M), Version 12.2(13)JA4, EARLY DEPLOYMENT RELEASE
SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Fri 16-Apr-04 12:22 by cmong
Image text-base: 0x00003000, data-base: 0x0053CF74
ROM: Bootstrap program is C1200 boot loader
BOOTLDR: C1200 Boot Loader (C1200-BOOT-M) Version 12.2(8)JA, EARLY DEPLOYMENT RELEASE
SOFTWARE (fc1)
EwingWAP uptime is 6 days, 23 hours, 16 minutes
System restarted at 10:57:03 EDT Wed Jul 21 2010
System image file is "flash:/c1200-k9w7-mx.122-13.JA4/c1200-k9w7-mx.122-13.JA4"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AIR-AP1231G-A-K9     (PowerPC405GP) processor (revision B0) with 14326K/2048K b
ytes of memory.
Processor board ID FOC08332RGA
PowerPC405GP CPU at 196Mhz, revision number 0x0145
Last reset from power-on
Bridging software.
1 FastEthernet/IEEE 802.3 interface(s)
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:12:00:3A:38:14
Part Number                          : 73-8704-07
PCA Assembly Number                  : 800-23211-08
PCA Revision Number                  : A0
PCB Serial Number                    : FOC08332RGA
Top Assembly Part Number             : 800-23304-07
Top Assembly Serial Number           : FTX0837R0BK
Top Revision Number                  : B0
Product/Model Number                 : AIR-AP1231G-A-K9
Configuration register is 0xF
Surendra BG Wed, 07/28/2010 - 08:37
  • Cisco Employee,
Whats the error msg that we are getting at the time we try opening  the GUI??
Surendra
jasonww04 Thu, 10/28/2010 - 09:56
No error message. Just keeps prompting for username and password and then after 3rd failure it goes to Authorization Required page.
Scott Fella Fri, 10/29/2010 - 04:50
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
That's weird... I would try to add another username with privilege 15 and maybe a different browser to see if maybe the browser doesn't like something.
Correct Answer
Surendra BG Sun, 10/31/2010 - 08:01
  • Cisco Employee,
Hi Jason,
Username - Cisco
Password - Cisco
en
conf t
aaa new-model
end
Surendra
jasonww04 Mon, 11/01/2010 - 10:14
adding the AAA code worked. Thanks for all the help.
Surendra BG Mon, 11/01/2010 - 18:03
  • Cisco Employee,
Thanks for posting on CSC!!
Surendra
