07-21-2010
08:12 AM
- last edited on
02-21-2020
11:21 PM
by
cc_security_adm
I have two ASA's, soon to have several more out in the field connecting little networks together. My main ASA has a site to site built between itself and another ASA (Main ASA5520 / Other ASA5505).
I can SSH or telnet to the 5505, even to its internal IP, but my current problem is although within the network I cannot ping other devices from the 5505, which is contained within our network. I try to update the ASA using TFTP but that fails as well. I know it has something to do with icmp but I think I'm missing something.
When I attempt to do a traceroute to an internal ip it fails.
911PSAP-5505# traceroute 192.255.255.13
Tracing the route to 192.255.255.13
1 68.213.181.241 0 msec 0 msec 0 msec
2 68.216.208.95 20 msec 10 msec 10 msec
3 68.152.198.81 10 msec 10 msec 10 msec
4 12.81.24.108 10 msec 10 msec 10 msec
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
Solved! Go to Solution.
07-21-2010 09:15 AM
The tftp command is to specify the tftp server where the file will be retrieved from. ASA can't act as a TFTP server.
Are you trying to ping devices in the same subnet as your ASA interface? You might want to check the device firewall settings itself where sometimes it's not allowing inbound ping, so disabling firewall setting might resolve your ping test issue. If you try to ping a network device, like a switch or a router from the ASA, you might have better luck.
07-21-2010 08:25 AM
You might want to check that you have "icmp permit any
To check if you have the configuration or not: sh run icmp
With regards to TFTP, by default TFTP on the lowest security level interface is not allowed, unless you configure a TFTP interface as follows for example:
tftp-server
Hope that helps.
07-21-2010 09:10 AM
"icmp permit any
Already in place
tftp-server
Does this refer to the server it will be retreiving the file from or just utilizing the ASA as the server?
07-21-2010 09:15 AM
