SQL 2005 tools on uxxc 7.0
Jul 21st, 2010
Does anyone know or can anyone point me in the right direction, I am trying to find out if the SQL 2005 MS tools are support on the UCCX 7.01 box in a HA install.  We have a database for dips that is 2005 so we installed the tools for 2005 and we are having some weird issues with HR replication and reports don't run on the secondary box but they do run on the primary box and we are wondering if there is any chance this could be are problem.
Overall Rating: 5 (1 ratings)
Walter Solano Wed, 07/21/2010 - 08:22
  • Gold, 750 points or more
I have seen very weird issues when doing that, some times the SQL agent not even starts in any node. As you know UCCX 7.0(1) uses MS SQL 2000 data base and if you need to install any extra tool its better if you use the ones for SQL 2000
Walter Solano
Aaron Harrison Wed, 07/21/2010 - 08:27
  • Community Spotlight Award,
    Member's Choice, May 2015
Have you taken a look in System/Datastore Control Center in appadmin? I've seen issues with the datastores losing replication status on several occasions, sometimes seemingly of their own accord, and also after installing DB drivers and so on.
It can be fixed by deactivating/reactivating the failed datastore (i.e. HR in your case, possibly others) on the secondary via component activation.
Aaron
DAFitzgerald Wed, 07/21/2010 - 14:06
Thanks for the quick reply, I noticed that we are using SQL server native client for 2005 to make the DSN connection for the customer.  Should we also uninstall that as well or is that ok to leave as long as the 2005 tools and 2005 backward compatibility are removed?
