07-21-2010 09:14 AM - edited 03-06-2019 12:07 PM
I have a quick question, i have to deploy a 3750G switch to one of our sites and the interfaces are reading as if the switch was in a stack previously.
when i go to sh run all the interfaces come up as 2/0/1 - 2/0/24.This switch will not be in a stack so shouldn't the interfaces start with 1/0/1. And if
i need to change them what command would i use to correct this or is this something i shouldn't worry about.
Solved! Go to Solution.
07-21-2010 09:26 AM
Scooter,
This is most likely because the switch was stack member 2 the last time the 3750 was joined to a stack. If you wish to change the switch so it is once again stack member 1 you can use the following command in the global configuration mode:
switch 2 renumber 1
This command will take effect next time the device is reloaded. For more information about stack member numbers, follow the following link:
BK
07-21-2010 09:26 AM
Scooter,
switch 2 renumber 1
BK
07-21-2010 09:53 AM
i used this command "switch 2 renumber 1 " and now when i look i have interfaces 1/0/1 - 1/0/24 and 2/0/1 - 2/0/24.
Did I input the command correctly
07-21-2010 10:07 AM
I just did a wr erase and it fixed the problem, thanks for your help
