cisco unity 8.0 installation problem
Jul 21st, 2010
Dear all
I have unity 8.0
I installed any prereq. for it.
but the strange problem is during installation it retunrs error :
Event Type: Error
Event Source: CiscoUnity_SysConfig
Event Category: (7)
Event ID: 1006
Date:  7/21/2010
Time:  5:50:02 PM
User:  N/A
Computer: UNITY
Description:
Cisco Unity Setup encountered an error while running configuration SQL script 'C:\CommServer\Localize\DefaultConfiguration\ENU\ENU_DefaultDatabasePrep.sql'
[Error 0x80004005]
also the  out put of OsqlDump_20100721_171648.txt is:
Msg 911, Level 16, State 1, Server UNITY, Line 22
Could not locate entry in sysdatabases for database 'UnityDB'. No
entry found with that name. Make sure that the name is entered
correctly.
i dont know what should my plan B!!
please help
its eactly when want to configure sql scripts..
i have done anything as cisco said in installation documents
dugward Fri, 09/16/2011 - 17:07
Please let me know if you fixed this? I have the same problem, we finally rebuilt the server, re installed everything and still same error, however now at least my sql is staying connected to the database folders, etc.....
