07-21-2010 10:22 AM - edited 03-19-2019 01:17 AM
We are operating with a cluster of three Callmanager 4.1.3 servers.
I have the all CDs paackage of Callmanager 4.1.3.
My question is : Is Cisco Unity a separate product I have to order, or is it shiped automatically with Callmanager ?
Best Ragards.
Solved! Go to Solution.
07-21-2010 10:28 AM
Different product with a whole different set of HW and SW requirements.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
07-21-2010 11:09 AM
Yes, different product. Different specialized hardware and software requirements. In any case, I would highly recommend looking towards Unity Connection as a first option depending upon your requirements.
Hailey
Please rate helpful posts!
07-21-2010 10:28 AM
java
07-21-2010 11:09 AM
Hailey
