stacking of switches
Jul 21st, 2010
According to SBA guide, If there are three or more switches in the stack, the uplinks should be on switches that are not stack master.
is there any particular reason .. the uplink should not be in stack master?
Aung
Leo Laohoo Wed, 07/21/2010 - 19:21
If the uplinks are on the stack master and the stack master should fail, what's going to happen to the switches downwind?
moaung_sg Thu, 07/22/2010 - 21:10
Thanks, so the best options is should installed uplink at all switches ports with L2 port channel ?
Leo Laohoo Thu, 07/22/2010 - 21:16
It means don't put all of your uplinks into one switch.  Spread `em around.
Jayakrishna Mada Mon, 08/02/2010 - 16:09
yes you can configure a port-channel if you are connecting the switch stack and other switch with multiple links, instead of spannig-tree blocking all ports expect one, it would be a good idea to use port-channel where we use all the bandwidth.
When configuring a port-channel across cross stack we cannot not use "PagP" protocol and it would be good to use "stack-mac persistent" command if you are using LACP protocol.
Here is a  good link on configuring etherchannel on 3750 stack:
http://www.cisco.com/en/US/customer/products/hw/switches/ps5023/products_configuration_example09186a00806cb982.shtml
JayaKrishna
