How to modify RADIUS Servers on a 4402 controller?
Jul 21st, 2010
I have several controllers, including a 4402 running software and I need to modify the Radius servers that it uses. Currently I have three servers listed;
1 -
2 -
3 -
I would like to delete server 1 which is being retired and replace it with a new server 1. I suspect, once i get servwe 1 deleted, the server 1 option would become available when I create a new server. I went into the controller and disabled server one, but every time I try and delete it, I get the "Server in use either on a specific WLAN or Mesh Radius Server Configuration" error. I can't find anywhere this server is still in service and being used, either by a WLAN or a Mesh. I've tried several different variances to modify this and have run out of ideas. What I hope to avoid is the need to reset the controller. I have a total of seven controllers that I need to make this modification to, and It will be ugly if I have to reboot these units. Hospital mission critical stuff.
Saravanan Lakshmanan Thu, 06/14/2012 - 16:03
did you try from cli.
you could disable the decomissioned rad server
are you able to delete other rad server, and or add/create new radius server then you are good for now
WLC>show switch config
May be the config is corrupt on wlc.
backup the config, delete the required radius server, restore the edited config, reboot the WLC, sorry
I had tried disabling all WLANs, deleting the WLAN which used the servers, neither helped.
Tried the same from the command line, which also did not help.
I was not able to change the shared secret for the Radius servers either, which was originally all I had wanted to do.
Fortunately most of my controllers are cookie cutter from one another and I was able to recover-config and copy the configuration of a WLC from a different hospital and change the relevant interfaces and all was well.
Parmanand Patil Tue, 04/08/2014 - 00:52
I am also facing the same problem, I did not get the solution from above post.
Can anyone help me as I am trying to configure the WLC to add into radius for MGT user authentication & its not working.
At the same time my network user's are being authenticated from radius server's configured in WLC.
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
