WAAS Mobile Mgr shows users connected even after they disconnect
Answered Question
I have a demo of WAAS Mobile 3.5 going and have noticed that even after users disconnect, I still see them listed under WAAS Mobile Manager. They'll show TCP connection status/statistics for last day/last hour even thought they're disconnected. My concern is that the data I'm showing/selling to the customer using the Management tab on Manager may be showing bogus information.
Has anyone noticed this or am I reading this incorrectly? Is this information historical, such as showing their last hour's performance of WHEN they were connected and the last TCP sessions of WHEN they were connected?
Thanks!
Mike.
Correct Answer by Kenneth Lanzillo about 6 years 9 months ago
You are reading it correctly. WAAS Mobile has a feature called persistent connections where the connection will remain open as the mobile client disconnects and reconnect with (potentially) a new access point or cell tower. This "bogus" connection can last up to an hour before it times out and disconnects. The advantage is that the client and server maintain the connection with the origin server while there is a temporary disconnect, while the con is that the connection takes up a license slot. If this is a problem, then you can disable persistent connections, but this is not recommended unless you are really tight on license slots...
-ken
Overall Rating: 5 (1 ratings)
Correct Answer
Kenneth Lanzillo Wed, 07/21/2010 - 17:30
-ken
Well, I guess the plot thickens. My customer sent me some screen shots- the user "dhayes"
is NOT VPNed in right, and ain fact the client IP address that WAAS Mobile shows, is being used by another VPN client as indicated by the ASA (who doesn't have WAAS Mobile). Note how DHayes shows a "connected" status......yeah, definitely not connected........Is this some kind of WAASM bug?
Any idea?
Thanks!
Kenneth Lanzillo Thu, 07/22/2010 - 07:22
WAAS Mobile will continue to show this user connected, despite the fact that he has actually disconnected and the IP has been resused, until the timer runs out and the persistent session is cancelled.
