Can LWAPP Support Wireless Bridging?
Answered Question
Jul 21st, 2010
Currently, I'm using 1242 APs in autonomous mode with wireless bridging function to provide wifi coverge to areas that cannot install LAN cables. (simplified configuration depicted below):
LAN ------UTP------ |1242| b/g radio ---- wireless link ----    b/g radio |1242| a radio ------ wireless link ---- a radio |1242 b/g| radio ---   wireless client
Would like to know if the 1242 APs operating in the above configuration can be changed to lightweight mode?
Thanks.
Correct Answer by rsreeves1 about 6 years 5 months ago
That is all correct.
-Rob
Overall Rating: 5 (1 ratings)
EW Thu, 07/22/2010 - 18:54
Thanks Rob,
I cannot access the reference document.
In the scenario with autonomous AP associated to lightweight APs, can the Cisco Wireless Control System Management Software be used to manage the autonomous APs? It is becasue it looks like autonomous APs have to be managed by CiscoWork Wireless LAN Solution Engine (/Express).
Tks...Eric
rsreeves1 Fri, 07/23/2010 - 12:21
WGB APs can be managed by WCS the same as any other autonomous AP.  WLSE is not required.  Here's what the WCS configuration guide has to say:
Work Group Bridge (WGB) Mode
Wireless Group Bridge (WGB) mode is a special mode where an autonomous access point functions as a wireless client and connects to a lightweight access point. The WGB and its wired clients are listed as client in WCS if the AP mode is set to Bridge, and the access point is bridge capable.
To view a list of all WCS clients that are WGBs, choose Monitor > Clients. At the Show drop-down menu, choose WGB Clients and click Go. The Clients (detected as WGBs) window appears. Click a User to view detailed information regarding a specific WGB and its wired clients.
Note The WCS provides WGB client information for the autonomous access point whether or not it is managed by the WCS. If the WGB access point is also managed by the WCS, WCS provides basic monitoring functions for the access point similar to other autonomous access points.
WCS manages configs on autonomous APs simply by applying templates with lists of CLI commands, nothing fancy there.  It's mostly useful for monitoring purposes.
I've attached the PDF for the WGB config guide I referenced in my last response.
-Rob
EW Mon, 07/26/2010 - 02:28
Thanks Rob. The WGB config guide clearly explained the usage.
Would like to recap my understandings:
1. Aironet 1242 AP in autonomous mode as WGB can associately wirelessly to lightweight AP;
2. Aironet 1242 AP in lighweight mode cannot support wireless bridging as what I'm using in Autonomous mode;
3. Autonomous AP can be managed by WCS whether it is in WGB mode or not.
Thanks.
Trending Topics - Security & Network
