Router 2811 IPsec VPN
Jul 22nd, 2010
we are trying to establish the VPN between Cisco 2811 router (Version 12.4(13r)T ) and PIX 515 E 7.01 and 7.23
but we are able to get the VPN status UP but unable to ping the IP ( encrpt the IP on the router side )
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
XX.XX.202.161 XXX.XX.37.10    QM_IDLE           1023 ACTIVE
Sh cry ipsec sa on Router side :
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (192.168.148.0/255.255.252.0/0/0)
   remote ident (addr/mask/prot/port): (10.215.0.0/255.255.0.0/0/0)
   current_peer XXX.XX.37.10 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
    #pkts decaps: 1764, #pkts decrypt: 1764, #pkts verify: 1764
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 0, #recv errors 0
     local crypto endpt.: XXX.XXX.202.161, remote crypto endpt.: XXX.XXX.37.10
     path mtu 1500, ip mtu 1500, ip mtu idb FastEthernet0/1
     current outbound spi: 0x4D0B702(80787202)
     PFS (Y/N): N, DH group: none
     inbound esp sas:
      spi: 0x3861D560(945935712)
        transform: esp-3des esp-md5-hmac ,
        in use settings ={Tunnel, }
        conn id: 2015, flow_id: NETGX:15, sibling_flags 80000046, crypto map: St
oS-VPN
        sa timing: remaining key lifetime (k/sec): (4438146/704)
        IV size: 8 bytes
        replay detection support: Y
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 2016, flow_id: NETGX:16, sibling_flags 80000046, crypto map: St
oS-VPN
        sa timing: remaining key lifetime (k/sec): (4438204/704)
        IV size: 8 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
kindly suggest us what might be the issue
Jennifer Halim Thu, 07/22/2010 - 02:51
  • Cisco Employee,
Base on the output of "show cry ipsec sa" on the router, traffic arrives in the router and getting decrypted, however, it doesn't get encrypted to be sent towards the PIX end.
You might want to check if NAT exemption has been configured on the router for traffic between 192.168.148.0/22 towards 10.215.0.0/16.
If you can share the router config, we might be able to spot something.
Hope that helps.
vinoth.kumar Thu, 07/22/2010 - 02:58
Thanks for your reply
router config:
Building configuration...
Current configuration : 3345 bytes
version 12.4
service password-encryption
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip domain name yourdomain.com
archive
log config
  hidekeys
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 2
encr 3des
group 2
crypto isakmp policy 3
group 2
crypto isakmp policy 4
hash md5
crypto isakmp policy 5
encr 3des
crypto isakmp key XXXXXX address XXX.XX.37.10
crypto ipsec transform-set TEST_VPN esp-3des esp-md5-hmac
crypto map StoS-VPN 21 ipsec-isakmp
set peer XXX.XXX.37.10
set transform-set TEST_VPN
match address 116
interface FastEthernet0/1
  ip address XXX.XXX.202.161 255.255.255.240
ip nat outside
ip virtual-reassembly
load-interval 30
duplex full
speed 100
crypto map StoS-VPN
interface FastEthernet0/3/0
switchport access vlan 100
interface FastEthernet0/3/1
interface FastEthernet0/3/2
interface FastEthernet0/3/3
interface Vlan1
no ip address
interface Vlan100
ip address 192.168.151.3 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 XXX.XXX.203.162
ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool TEST XXX.XXX.202.161 XXX.XXX.202.161 netmask 255.255.255.252
ip nat inside source route-map nonat pool TEST overload
logging 192.168.151.220
access-list 102 deny   ip 192.168.148.0 0.0.3.255 10.215.0.0 0.0.255.255
access-list 102 permit ip 192.168.148.0 0.0.3.255 any
access-list 116 permit ip 192.168.148.0 0.0.3.255 10.215.0.0 0.0.255.255
route-map nonat permit 10
match ip address 102
manish arora Thu, 07/22/2010 - 09:23
  • Silver, 250 points or more
question :- why do you have the ip address of interface vlan 100 subnet mask as /24 instead of /22 ?
can you please post some debugs ( isakmp , ipsec ) and also sh ip route on this router ?
thanks
manish
vinoth.kumar Thu, 07/22/2010 - 21:27
HI
We have L3 swicth from there we are routing remote subnet to the router
interface 192.168.151.3
routing table in L3 :
#sh ip route
Ip Route
DST MASK NEXT COST VLAN PORT PROT
TYPE
Jitendriya Athavale Thu, 07/22/2010 - 22:27
  • Cisco Employee,
are you able to ping the vlan 100 ip
also just wondering if you will need a route for the 192.168.148 network point to the next hop on inside
also what we need to see is if the return traffic is actually coming to the router
can you apply this access-list on the vlan 100
ip access-list extended 199
10 permit ip 192.168.148.0 /22 10.x.x.x
20 permit ip any any
int vlan 100
ip access-group 199 in
lets see if we see any hit counts on the 199
please note the line 10 in 199 is the interesting traffic.
vinoth.kumar Fri, 07/23/2010 - 03:05
please find the result after applied to interface
Extended IP access list 199
10 permit ip 192.168.148.0 0.0.3.255 10.215.0.0 0.0.255.255 (31 matches)
20 permit ip any any (780 matches)
#sh version
Cisco IOS Software, 2800 Software (C2800NM-ADVSECURITYK9-M), Version
12.4(24)T3,
RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 23-Mar-10 06:43 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
is there any issue with IOS platform
thanks
Vinu
On Fri, Jul 23, 2010 at 10:57 AM, jathaval <
Jitendriya Athavale Fri, 07/23/2010 - 04:33
  • Cisco Employee,
can you take the debugs and attach it please
we would require both isakmp and ipsec debug if possible
vinoth.kumar Fri, 07/23/2010 - 06:59
HI
Can u pls find the below debug log
*Jul 23 14:01:16.895: ISAKMP:(1025):Old State = IKE_QM_SPI_STARVE New State
= I
KE_QM_R_QM2
*Jul 23 14:01:16.895: IPSEC(key_engine): got a queue event with 1 KMI
message(s)
message(s)
*Jul 23 14:01:16.895: Crypto mapdb : proxy_match
src addr : 192.168.148.0
dst addr : 10.215.0.0
protocol : 0
src port : 0
dst port : 0
*Jul 23 14:01:16.899: IPSEC(crypto_ipsec_sa_find_ident_head): reconnecting
with
the same proxies and peer XXX.XXX.37.10
*Jul 23 14:01:16.899: IPSEC(policy_db_add_ident): src 192.168.148.0, dest
10.215
.0.0, dest_port 0
*Jul 23 14:01:16.899: IPSEC(create_sa): sa created,
(sa) sa_dest= XXX.XXX.202.161, sa_proto= 50,
sa_spi= 0x802AB1AF(2150281647),
sa_trans= esp-3des esp-md5-hmac , sa_conn_id= 2077
sa_lifetime(k/sec)= (4576146/3600)
(sa) sa_dest= XXX.XXX.37.10, sa_proto= 50,
sa_spi= 0x9319ECF9(2467949817),
sa_trans= esp-3des esp-md5-hmac , sa_conn_id= 2078
*Jul 23 14:01:17.115: ISAKMP (1025): received packet from XXX.XXX.37.10
dport 500
sport 500 Global (R) QM_IDLE
*Jul 23 14:01:17.119: ISAKMP:(1025):deleting node 1232130872 error FALSE
reason
"QM done (await)"
*Jul 23 14:01:17.119: ISAKMP:(1025):Node 1232130872, Input =
IKE_MESG_FROM_PEER,
IKE_QM_EXCH
*Jul 23 14:01:17.119: ISAKMP:(1025):Old State = IKE_QM_R_QM2 New State =
IKE_QM
PHASE2COMPLETE
*Jul 23 14:01:17.119: IPSEC(key_engine): got a queue event with 1 KMI
message(s)
*Jul 23 14:01:17.119: IPSEC(key_engine_enable_outbound): rec'd enable notify
fro
m ISAKMP
*Jul 23 14:01:17.119: IPSEC(key_engine_enable_outbound): enable SA with spi
2467
949817/50
*Jul 23 14:01:17.119: IPSEC(update_current_outbound_sa): updated peer
XXX.XXX.37.
10 current outbound sa to SPI 9319ECF9
*Jul 23 14:01:36.091: IPSEC(crypto_map_check_encrypt_core): CRYPTO: Packet
dropp
ed because cryptomap is currently being created
dropp
*Jul 23 14:01:36.095: IPSEC(crypto_map_check_decrypt_core): CRYPTO: Packet
dropp
ed because cryptomap si currently being created
dropp
Vinu
On Fri, Jul 23, 2010 at 5:03 PM, jathaval <
manish arora Fri, 07/23/2010 - 10:30
Try adjusting  the MTU on both sides PIX as well as your router. It appears that the packets are coming in DF bit set to 1. try using extended ping with diffrent MTU and debug ip icmp. post config of both sides router & PIX. also make sure if you are running remote vpn access on any side , its crypto map is higher than L2L.
I am more than confident that it is a MTU issue + DF set  do not fragment, as the phase 1 and phase 2 are completed as per the debug on router side.
thanks
Manish
Jitendriya Athavale Fri, 07/23/2010 - 11:09
  • Cisco Employee,
sometimes we see crypto map being still applied message due to mis match in crypto identities
can you please paste the config on the other end as weel
looks like crypto acl mismatch can you please confirm again that the phase 2 config is matching on both end, i am particular worried about 192.168.148 network bcoz that has /23 mask and in the identitied it looks like it might have /24
can yo uplease confirm that
vinoth.kumar Mon, 07/26/2010 - 00:14
HI,
i have small quey that whether the router required any activation key
somthing like to encry and decrpty the traffic
kinldy advice
On Fri, Jul 23, 2010 at 11:40 PM, jathaval <
HI,
kinldy advice
On Fri, Jul 23, 2010 at 11:00 PM, manisharora111 <
Jitendriya Athavale Mon, 07/26/2010 - 05:19
  • Cisco Employee,
i dont think so u need anytihng of tht sort, it depends on image and probably if you didnt have the right image it wouldnt let u enter the commands in the first place
it looks like a config issue in phase 2
can you please paste the config on both ends
vinoth.kumar Mon, 07/26/2010 - 05:39
Pls find the below config
Router config
version 12.4
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
ip cef
archive
log config
hidekeys
hash md5
group 2
group 2
group 2
hash md5
encr 3des
crypto isakmp key XXXXXX address XXX.XXX.37.10
crypto isakmp invalid-spi-recovery
crypto ipsec transform-set XXXXX-VPN esp-3des esp-md5-hmac
set peer XX.XX.37.10
set transform-set XXXXX-VPN
match address 116
interface FastEthernet0/0
description PTP TO ISP
ip address XXX.XXX.203.161 255.255.255.252
load-interval 30
duplex auto
speed 100
description WAN_INTERFACE
ip nat outside
load-interval 30
duplex full
speed 100
crypto map StoS-VPN
interface Vlan1
no ip address
interface Vlan100
ip nat inside
router bgp 17488
no synchronization
bgp log-neighbor-changes
no auto-summary
ip http server
access-list 102 deny ip 192.168.151.0 0.0.0.255 10.215.0.0 0.0.255.255
access-list 102 permit ip 192.168.151.0 0.0.0.255 any
access-list 116 permit ip 192.168.151.0 0.0.0.255 10.215.0.0 0.0.255.255
snmp-server community public RW
snmp-server enable traps snmp authentication linkdown linkup coldstart
warmstart
snmp-server enable traps cpu threshold
snmp-server host 10.89.2.10 public
control-plane
line con 0
line aux 0
scheduler allocate 20000 1000
PIX Config
: Saved
PIX Version 8.0(4)
hostname PRI-PIX-FW-SYD1
domain-name SYD-GS
enable password MSV2FjMCpOHCDb7R encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0
description PIX WAN INTERFACE
nameif outside
security-level 0
ip address XXX.XXX.37.10 255.255.255.224
interface Ethernet1
nameif inside
security-level 100
ip address 10.215.1.10 255.255.255.0
interface Ethernet2
shutdown
no nameif
security-level 80
no ip address
interface Ethernet3
shutdown
no nameif
no security-level
no ip address
interface Ethernet4
shutdown
no nameif
no security-level
no ip address
interface Ethernet5
description STATE Failover Interface
speed 100
duplex full
ftp mode passive
dns server-group DefaultDNS
access-list VPN-XXX extended permit ip 10.215.0.0 255.255.0.0 192.168.151.0
255.255.255.0
access-list NO_NAT extended permit ip 10.215.0.0 255.255.0.0 192.168.151.0
255.255.255.0
pager lines 24
logging enable
mtu outside 1500
mtu inside 1500
ip local pool RemoteVPNpool 10.215.254.241-10.215.254.246
failover
failover link state Ethernet5
failover interface ip state 172.16.50.1 255.255.255.0 standby 172.16.50.2
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
asdm image flash:/asdm-613.bin
no asdm history enable
arp timeout 14400
global (outside) 1 XXX.XXX.37.6
nat (inside) 0 access-list NO_NAT
access-group Outside_inside in interface outside
route outside 0.0.0.0 0.0.0.0 XXX.XXX.37.1 1
route inside 10.215.10.0 255.255.255.0 10.215.1.1 1
route inside 10.215.11.0 255.255.255.0 10.215.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat
0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect
0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set XXXXXXX-set esp-des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map VPN_IPSEC 5 match address VPN-XXX
crypto map VPN_IPSEC 5 set peer XXX.XXX.202.161
crypto map VPN_IPSEC 5 set transform-set XXXXXXX-set
crypto map VPN_IPSEC 5 set security-association lifetime seconds 28800
crypto map VPN_IPSEC 5 set security-association lifetime kilobytes 4608000
crypto map VPN_IPSEC interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 9
encryption des
hash md5
group 2
lifetime 86400
crypto isakmp policy 10
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 11
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 13
encryption 3des
hash md5
group 1
lifetime 86400
crypto isakmp policy 15
encryption 3des
hash sha
group 2
lifetime 3600
crypto isakmp policy 16
encryption aes-256
hash sha
group 5
lifetime 28800
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
telnet 192.168.0.0 255.255.255.0 inside
telnet 10.0.0.0 255.0.0.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
management-access inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
tunnel-group XXX.XXX.202.161 type ipsec-l2l
tunnel-group XXX.XXX.202.161 ipsec-attributes
pre-shared-key X
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
thanks
Vinu
On Mon, Jul 26, 2010 at 5:49 PM, jathaval <
manish arora Mon, 07/26/2010 - 08:48
Can you please issue this command on the PIX :-
crypto ipsec df-bit clear-df outside
thanks
Manish
vinoth.kumar Mon, 07/26/2010 - 09:01
No luck
its same as before
On Mon, Jul 26, 2010 at 9:18 PM, manisharora111 <
Jitendriya Athavale Mon, 07/26/2010 - 10:00
  • Cisco Employee,
can you try clearing the tunnel and establish again
plz try the following
clear cry sa
clear crypto sessions
remove crypto map from the interface
reapply it
and then try to bring the tunnel up
manish arora Mon, 07/26/2010 - 15:54
Did clearing the crypto map helped at all ?
If not , then can yu please make the following changes  on the router side :-
1> remove the non default "crypto isakmp invaild-spi-recovery" command.
2> place the match statement before the set statements in the crypto map configuration.
3> do isakmp , ipsec and engine debugs  + system logs from both router and pix  for more research on the matter.
thanks
Manish
