ASA FTP speed problem
Jul 22nd, 2010
I have the problem with ftp speed to server behind the ASA.
I found out that this issue occurs in all our location (where we have ASA and some ftp server behind)
I have create some lab (only two hosts connected and no unnecessary configurations) :
inside network (client PC)  ------ASA 5505 8.2(1)------- DNZ network (ftp server)
When I'm trying to download some files from the DMZ ftp serverer I have never had speed more than 4MBytes/s.
When I'm opening 2 sessions, speed is decreasing to about 2 MB/s.
At the same time when I'm trying to access the ftp server via SMB I can download files 3 times faster (about 12 MB/s) - so almost max FEth speed.
When I moved the server to inside network (both: client PC and ftp server were in the same network) I ccould download files using ftp service at the same speed like using SMB.
ASA config:
interface Vlan1
nameif dmz
security-level 100
ip address 10.0.19.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 10.10.10.1 255.255.255.0
interface Ethernet0/0
interface Ethernet0/2
switchport access vlan 2
access-list dmz extended permit ip any any
access-list outside extended permit ip any any
access-group dmz in interface dmz
access-group outside in interface outside
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect ftp
service-policy global_policy global
The rest of configuration is default.
I have tested this on ASA5520 as well and it looks the same.
Now this is a big problem for us, because we have a separate link to assure max speed for our clients but it looks that ASAs restrict the throughput.
thanks in advance for your help.
I hope that we will not have to change ASAs to other FWs ....
best
James
Jitendriya Athavale Thu, 07/22/2010 - 06:02
  • Cisco Employee,
could you please paste the output of show interface for the interface on firewall connected to dmz
so what i want to check is
interface drops
duplex and speed settings (hard code on both sides if possible)
traffic statistics on this interface
---> also i have a question here, what about non ftp traffic are you getting expected speed from dmz interface
also when you say you get good speed when connected on inside, do you mean inside interface of firewall (just wanted to confirm because i dont see any inside config in the config screen shot)
Tomasz Mowinski Thu, 07/22/2010 - 06:53
All others protocols work with maximum available speed. Only ftp is slow....
I have good speed using ftp protocol when I move ftp server to the same LAN as client PC (sorry but in configuratio I used "outside" name intead of "inside").
It means change ftp server IP address from 10.0.19.0/24 network to 10.10.10.0/24 and reconfigure interface Eth0/0 to accless vlan 2.
So it looks that some ASAs processes slow down the traffic. ACLs, routing ... ??
Below you can find interfaces/traffic statistics:
DMZ:
ciscoasa# sh int et 0/2
ciscoasa# sh int et 0/0
Interface Ethernet0/0 "", is up, line protocol is up
  Hardware is 88E6095, BW 100 Mbps, DLY 100 usec
        Auto-Duplex, Auto-Speed
        Available but not configured via nameif
        MAC address c47d.4f89.2129, MTU not set
        IP address unassigned
        424860 packets input, 459035841 bytes, 0 no buffer
        Received 72 broadcasts, 0 runts, 0 giants
        0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
        0 L2 decode drops
        0 switch ingress policy drops
        212173 packets output, 13579115 bytes, 0 underruns
        0 late collisions, 0 deferred
        0 input reset drops, 0 output reset drops
        0 rate limit drops
        0 switch egress policy drops
Inside:
Interface Ethernet0/2 "", is up, line protocol is up
        Auto-Duplex(Full-duplex), Auto-Speed(100 Mbps)
        MAC address c47d.4f89.212b, MTU not set
        677532 packets input, 44516824 bytes, 0 no buffer
        Received 58 broadcasts, 0 runts, 0 giants
        0 L2 decode drops
        1329221 packets output, 1522574031 bytes, 0 underruns
        0 rate limit drops
Aggregated Traffic on Physical Interface
Ethernet0/0:
        received (in 308.570 secs):
                424860 packets  459035841 bytes
                1376 pkts/sec   1487623 bytes/sec
        transmitted (in 308.570 secs):
                212173 packets  13579115 bytes
                687 pkts/sec    44006 bytes/sec
      1 minute input rate 0 pkts/sec,  0 bytes/sec
      1 minute output rate 0 pkts/sec,  0 bytes/sec
      1 minute drop rate, 0 pkts/sec
      5 minute input rate 1416 pkts/sec,  1530103 bytes/sec
      5 minute output rate 707 pkts/sec,  45263 bytes/sec
      5 minute drop rate, 0 pkts/sec
Ethernet0/2:
        received (in 6494.160 secs):
                677532 packets  44516824 bytes
                104 pkts/sec    6193 bytes/sec
        transmitted (in 6494.160 secs):
                1329221 packets 1522574031 bytes
                204 pkts/sec    234452 bytes/sec
      5 minute input rate 1041 pkts/sec,  66667 bytes/sec
      5 minute output rate 2082 pkts/sec,  2253325 bytes/sec
I appreciate your help.
best
James
Jitendriya Athavale Thu, 07/22/2010 - 08:30
  • Cisco Employee,
can you please paste the entire config so that we can take a look at inspection, nat rules and acl etc
by the way what ftp are you using passive or active
also one thing that you can try is from the dmz interface will it possible for you to plug the PC directly into the asa and test the ftp speed
Tomasz Mowinski Sun, 07/25/2010 - 23:36
Here you are:
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif dmz
security-level 100
interface Vlan2
nameif outside
security-level 0
interface Ethernet0/1
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/
boot system disk0:/asa821-k8.bin
ftp mode passive
pager lines 24
logging enable
logging buffered informational
logging asdm informational
mtu dmz 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 dmz
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
management-access dmz
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
  inspect ftp
prompt hostname context
Cryptochecksum:007dd63f4f6a351df76ab4de0ce73425
: end
I tested it usung both: passive and active modes. Speed was the same.
I have both devices (the client PC and the server) directly connected to ASA. No switches between.
best
James
Jitendriya Athavale Mon, 07/26/2010 - 00:05
  • Cisco Employee,
plz try the following
remove ftp inspect
and try passive client as this does not require inspection
bcoz the only inspection i see is ftp so just want to verify tht this inspection is not the issue
Jitendriya Athavale Mon, 07/26/2010 - 05:11
  • Cisco Employee,
can you collect some captures on both the inside and dmz for the 2 way ftp traffic
also can you plaste the following output
clear service-policy
clear asp drops
show service-policy
show asp drops
after you try to access the server
Tomasz Mowinski Mon, 07/26/2010 - 23:55
I've attached two files with capture and here you are the show-policy and asp drop output after access the ftp server:
ciscoasa# sh service-policy
Global policy:
  Service-policy: global_policy
ciscoasa# sh asp drop
Frame drop:
  Flow is denied by configured rule (acl-drop)                                 9
Last clearing: 21:40:30 UTC Jul 26 2010 by enable_15
Flow drop:
regards
James
Deniz Miscioglu Sun, 11/13/2011 - 13:38
Hi There,
We are also having the same problem.
Just wanted to ask if this has been resolved and how?
Best,
Deniz
