Upgrade path for a 1200 series wireless access point
Jul 22nd, 2010
I have a AIR-AP1231G-A-K9  Wireless access point that is current running ISO 12.2(15)AJ. My question is this. Does anybody know if there's an ISO upgrade for the unit?  I looked on the CISCO site and could not find any info about and upgrade path for this ISO release.
          Reggie
dancampb Thu, 07/22/2010 - 06:15
  • Cisco Employee,
There really isn't any interim upgrades that would be required.  The  format of the config changes in version 12.3(4)JA if I remember  correctly.  All this really means is if you upgrade past this version you will not be able to downgrade below this version without having to reconfigure your SSIDs.
reggiewilliams Thu, 07/22/2010 - 06:38
So we can upgrade to 12.3(8)JA or higher? Would there be any reason not to upgrade? The current revision works fine so would it be best just to stay with this version?
          Reggie
Vinay Sharma Sun, 05/29/2011 - 07:18
  • Gold, 750 points or more
Are you still facing this issue?
thanks,
Vinay
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
