3750 stack member monitoring
Answered Question
Here is a problem with monitoring members in cisco 3750 stack.
Some info:
- Cisco Catalyst 3750-E
- 3 members in stack (1 24-port switch and 2 48-port switch)
- management ip address assigned to int vlan 1
-snmp service configured
Our task is monitoring the current state of stack members by snmp and
obtain temperature sensor information, fan status and power supply status.
With additional MIBs taken from cisco.com site we could obtain only
information from temperature sensors.
But fan status and power supply status of each member we can not
obtain. SNMP give such info only about stack master and no about other
members.
Can anybody suggest some way to solve this problem?
Correct Answer by Ganesh Hariharan about 6 years 9 months ago
Thanks, but
A switch cluster is different from a switch stack.
We have switch stack.
The best way to go about this is by use of the CiscoStackWiseMIB using snmp.Check out the below links for examples
http://jaguar.ir.miami.edu/cgi-bin/snmptransc.cgi
and in the "Object Identifier or Object Name" box, put .1.3.6.1.4.1.9.9.500
Select "tree translation" and you'll see all of the MIB objects this MIB supports.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_white_paper09186a00801b096a.shtml (stackwise white paper)
http://www.cisco.com/en/US/products/sw/iosswrel/ps5012/prod_bulletin0900aecd803fdbd8.html
Hope to help !!
Ganesh.H
Overall Rating: 5 (2 ratings)
Ganesh Hariharan Fri, 07/23/2010 - 01:24
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Some info:
members.
Check out the below link for monitoring cluster switches
http://www-europe.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_se/configuration/guide/swclus.html#wp1029200
Hope to help !!
Ganesh.H
Correct Answer
Ganesh Hariharan Fri, 07/23/2010 - 03:53
Thanks, but
Hope to help !!
Ganesh.H
Aung Moe Oo. Mon, 01/03/2011 - 05:38
Orion able to monitor stack port.
Does Cisco Works LMS can monitor stack port?
denizkaya Sat, 09/19/2015 - 06:10
monitoring stack port and monitoring stacked switch status are two different things
is orion bringing out all these status events? ;)
1waiting
2progressing
3added
4ready
5sdmMismatch
6verMismatch
7featureMismatch
8newMasterInit
9provisioned
10invalid
11removed
