BGP network command
Answered Question
Jul 22nd, 2010
If I enter the following two network commands:
network 172.20.0.0
network 172.16.3.0
Will BGP pick up that the 172.20.0.0 network is a /16 and that the 172.16.3.0 is a /24 or do i need to use the mask portion of this command?
Correct Answer by francisco_1 about 6 years 8 months ago
The behavior of the network command varies depending on whether auto-summary is enabled or disabled. When auto-summary is enabled, it summarizes the locally originated BGP networks (network x.x.x.x) to their classful boundaries (auto-summary is enabled by default in BGP).
When auto-summary is disabled, the routes introduced locally into the BGP table are not summarized to their classful boundaries.
Francisco.
See this http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800945ff.shtml
Francisco
Overall Rating: 5 (2 ratings)
milan.kulik Thu, 07/22/2010 - 08:26
  • Red, 2250 points or more
BGP network command is expecting a classful network used.
network 172.20.0.0
is OK, as 172.20.0.0 is a class-B network.
For a classless prefix, you need to use
network 172.16.3.0 mask 255.255.255.0
command form.
IMHO,
network 172.16.3.0
is treated as a configuration error - surprisingly does not bring any error message/warning unlike "network 172.16.3.0 mask 255.255.0.0" does.
HTH,
Milan
Correct Answer
francisco_1 Thu, 07/22/2010 - 08:42
  • Gold, 750 points or more
Francisco.
Francisco
