ACE4710 Rack Mounting problem
Jul 22nd, 2010
Hi there. Hope you can help.
I have just installed 2 ACE 4710 load Balancers into a 42U HP rack. We have mounted the rails
that came with the 4710's in the racks as specified. However, when we slide the uniserver
t into the rails it does not go fully home. There is about an inch gap between the 4710 front panel where the securing screws are housed and the actual cage nut located in the rack. The device will not fit flush with the racking! This cannot be right but I can see no way in which it can fit flush as the rails sliding system is fully closed up against its stops. There is no way you can mount the rails or side rails wrong so am i going mad????
paulm1bds Sun, 08/01/2010 - 23:28
Andy,  You have made the mistake of adjusting the rear rails only.  You needed to adjust the front rails.  The two phillips screws are accessible by sliding the rails forward until the screw heads become visible.  The front screw needs to be removed entirely and moved to a more suitable preset hole.  I do not understand why service rails are included anyhow as you cannot service this unit in the service position.  Maybe it is so that you can read the unit serial number which is stuck to the top of the unit!
rzsqlj000 Tue, 08/03/2010 - 01:25
Many thanks for the response. Will try what you suggest and let you know the outcome.
Environments Manager
Foreign and Commonwealth Office (FCO)
HP Enterprise Services
Telephone +44 1908.852213
Mobile +44 7790.493846
Email [email protected]
FCO Email [email protected]
Hanslope Park,Building 109,Hanslope / Milton Keynes. Bucks MK19 7BH
HP Enterprise Services UK Ltd
Registered Office: Cain Road, Bracknell, Berkshire, RG12 1HN
Registered no: 53419 England
The contents of this message and any attachments to it are confidential and may be legally privileged.  If you have received this message in error, you should delete it from your system immediately and advise the sender. To any recipient of this message within HP, unless otherwise stated you should consider this message and attachments as "HP CONFIDENTIAL".
Related Content
