Removing VTP domain name???
Jul 22nd, 2010
Hello everyone,
I have a 3550 < IPBASEK9-M > running version 12.2<40>SE software.
There is a VTP domain name setup on the switch.
I am using the Transparant mode on the switch.
I also have created an extended vlan.
How do I remove the VTP domain name.  I do not want a name configured on the switch.
Thanks for your help,
Matt
Overall Rating: 5 (1 ratings)
ch_sajid_hussain Thu, 07/22/2010 - 08:22
>enable
#vlan database
#no vtp domain (name)
Ganesh Hariharan Fri, 07/23/2010 - 01:18
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hello everyone,
Matt
Hi Matt,
The default domain is null in vtp mode,Note once you've changed a switch's VTP domain to something other than null,there is no way to change it back to null short of erasing the configuration and rebooting.
Hope to Help !!
Ganesh.H
rdkoning Wed, 11/17/2010 - 07:57
Hi All,
It's quite simple
Write erase
Delete flash:vlan.dat
reboot and your switch is in factory default.
The vlan.dat file is recreated.
You can now upload your cleaned config again and recreate the vlan's (make a backup before you do anything;-)
Best regards,
Robert
