Gilles Dufour Fri, 07/23/2010 - 04:19
  • Cisco Employee,
"show service summary" will show you a count of the active connections per service.
"show summary" gives you a count of the total connections per service per rule.
Finally, if you want to see the active connections "show flows 0.0.0.0".
Gilles.
bhhouston Fri, 07/23/2010 - 06:50
Thanks for the reply.
"show summary" is an accumulated total since the counters were reset, is it not?
"show flows 0.0.0.0" appears to show me the content connections but not the service connections, so no help there.
"show service summary" seems to be my best best but the "Conn" column has all zero's and I know for certain that I have approximately 300 connections across the services included in the content.  Why would the "Conn" column report all zero's?
Ben
Gilles Dufour Mon, 07/26/2010 - 00:00
  • Cisco Employee,
Ben,
the show flows 0.0.0.0 show both connections to the css and connections from the css.
If the 'show service summary' shows all 0, and you don't see connections from the css with the 'show flows 0.0.0.0' it does mean there is no connection on the backend.
Maybe you're on the standby unit ?
Gilles.
