IOS Upgrade
Jul 22nd, 2010
I am going to upgrade our 2821 wan router and am having difficulty in choosing the correct IOS. We are running spservices now and I would like to know the difference between SPSK9-SPSK9 Feature Set Factory Upgrade for Bundes versus just plain spservices.  Thanks for any help you can provide.
David Aicher Thu, 07/22/2010 - 13:08
  • Cisco Employee,
They are exactly the same image.  It is weird the way the tool puts it out there twice but there is apparently an underlying part number that shows up when the tool polls for existing images on the backend database.  The best way to tell is look at the real image name.  If they are identical and the image size is the same, then they are the same image.
Dave
