07-22-2010 12:11 PM - edited 03-04-2019 09:09 AM
Forum,
I am working at a client site today. I have come across a routing issue which has raised some quesitons.
Please look at the following config excerpt from the client router
router bgp 65001
no synchronization
bgp log-neighbor-changes
network 0.0.0.0
network 172.31.100.0 mask 255.255.255.0
network 192.168.5.0
network 192.168.15.0
redistribute static metric 30 route-map static-bgp-rm
redistribute eigrp 13 metric 20 route-map eigrp-bgp-rm
neighbor 12.115.94.169 remote-as 7018
neighbor 12.115.94.169 send-community
neighbor 12.115.94.169 soft-reconfiguration inbound
no auto-summary
Is it legal to use more than one "redistribute" statment in this BGP instance, or in any other dynamic routing protocol instance?
Kevin
Solved! Go to Solution.
07-22-2010 01:46 PM
This is supported. You should have a different redistribute statement for each protocol that is redistributed into the protocol in question.
router bgp XXXXX
redistribute eigrp
redistribute rip
redistribute ospf
redistribute connected
redistribute static
redistribute isis
Using a route map as is done in your example is a great method of preventing route loops as well as filtering routes between protocols.
Chris
07-22-2010 01:46 PM
router bgp XXXXX
redistribute eigrp
redistribute rip
redistribute ospf
redistribute static
redistribute isis
Chris
07-23-2010 03:47 AM
Hello Kevin,
this is a supported configuration
be aware that only routes installed in IP routing table are actually redistributed into target protocol
(BGP in this case)
you could even have static redistributed into EIGRP also and EIGRP and static routes redistributed into BGP.
Hope to help
Giuseppe
