Disconnect Cause=33 ?
Answered Question
Jul 22nd, 2010
Hi, guys and gals.
Does anyone know what a Disconnect Cause=33 means?
I am receiving this on calls placed to the PSTN from a 2851 gateway passing through a Siemens PBX? I don´t see that code tabulated in Cisco´s voice documentation. My calls establish themselves, but get cut at random intervals.
Doing a Q931 debug returns
Jul 22 21:26:47.000: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0xC77A
        Cause i = 0x80A181 - Unknown cause value
I am assuming the code is generated by Siemens.
Ariel
Correct Answer by Phillip Ratliff about 6 years 9 months ago
You are correct the far-end is sending the disconnect and not providing a reason.
Were you a part of this call?  It looks like the call was up for some time before it got dropped but you'll have to do some debugging on the PBX to see the real reason the call was ended.
-ryan
Overall Rating: 5 (1 ratings)
Phillip Ratliff Tue, 07/27/2010 - 07:07
  • Cisco Employee,
I'd guess that is them responding to a cause that was sent outbound to the Siemens.   Can you post the full debug (with edited numbers for privacy of course)?
arielroza Wed, 07/28/2010 - 12:12
This is the Debug:
Jul 22 21:25:03.525: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x4778 callID = 0xFDB7 switch = primary-qsig interface = User 0xC778 }
Jul 22 21:25:03.525: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x4778
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839E
                Exclusive, Channel 30
        Calling Party Number i = 0x0081, '12XXX'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '0155017XXXX'
Jul 22 21:25:03.717: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xC778
Jul 22 21:25:06.905: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8  callref = 0xC778
Jul 22 21:25:06.921: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8  callref = 0xC778
Jul 22 21:25:06.949: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0xC778
Jul 22 21:25:14.754: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0xC778
Jul 22 21:25:14.754: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x4778
Jul 22 21:26:46.972: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0xC778
Jul 22 21:26:46.972: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x4778
Jul 22 21:26:47.092: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xC778
        Cause i = 0x8090 - Normal call clearing
As I see, the Disconnect comes from the Siemens Side
Ariel
Correct Answer
Phillip Ratliff Wed, 07/28/2010 - 12:26
  • Cisco Employee,
-ryan
arielroza Wed, 07/28/2010 - 12:44
Thanks, Ryan!
That´s all I needed to confirm. The PBX is managed by another provider, I already passed the request, but was needing to confirm my suspicions.
Ariel.
