Warning message
Cisco Mobile 8.0 iPhone to Desk Phone Integration Error
Answered Question
Jul 22nd, 2010
Hi all,
I recently installed the Cisco Mobile 8.0 on my iPhone, and I'll be testing it for my users too. I have been able to configure everything as the Administration Guide for CiscoMobile8.0 for iPhone suggests, and make calls. Except for one feature. The Deskphone to iPhone integration.
I've set it up exactly as the manual suggests but when I try to configure the Deskphone integration part I get an error saying that my credentials are not correct. Now I know that they are correct because if they weren't I wouldn't be able to start and register the phone in the first place (SIP Digest).
Has anyone done this successfully?
My info:
I run a 7.1.3 Cluster of 2 UCMs 7845
I have ldap enabled authentication (which works perfectly) through our internal Windows domain.
I have over 1000 phones registered.
My ultimate goal for this is to enable Mobility on these "Cisco Dual Mode for iPhone" phones (leave it to Cisco to name something this long for an iPhone app)
Djassi
Correct Answer by benjaminwatt about 7 years 3 weeks ago
Hi Djassi,
Take a look at other threads such as this one. Cisco Mobile 8.0 for iPhone uses the CTIManager service to authenticate for the Desk Phone Integration, just like the CUPC does.
The invalid credentials problem in Cisco Mobile 8.0 is caused by the same things that make it not work in CUPC.
In your case if your LDAP directory uses Active Directory, there's a fair chance that changing the port of your LDAP directory to 3268 instead of 389, will fix this problem as soon as you restart the CTIManager service.
Certain LDAP filters can also cause this problem with any LDAP directory type, so if you've got any LDAP filters you may have to simplify these.
Overall Rating: 5 (1 ratings)
Correct Answer
benjaminwatt Sat, 07/24/2010 - 13:24
  • Bronze, 100 points or more
Hi Djassi,
djassi Mon, 07/26/2010 - 09:25
Hi Ben,
Thanks for your suggestion, and it worked like a charm on port 3268.
I was actually using the 686 SSL LDAP port, but when I tried to use the SSL port for the GC (3269) it gives me the same error. I have to check with my AD Admin about using these ports instead for better security.
Again thanks for the heads up.
Djassi
benjaminwatt Mon, 07/26/2010 - 10:11
Djassi,
Glad you've got it connecting now. To make it work on port 3269, you'd need to install the SSL certificate from your AD server onto the Communications Manager.
See this Cisco documentation, and also this useful thread.
Wildcard certificates don't work though, so hopefully your AD server isn't using one - this issue is currently biting us!
Ben
djassi Mon, 07/26/2010 - 13:03
Thanks again Ben,
I actually already had the certificates on the server already. I changed the port back to 3269 and this time it worked. Not sure what happened the last time.
Thanks for your help.
Djassi
