spa3102 provisioning: error http_get failed
brunosalzano
i'm experiencing a problem with provisioning on a spa3102: if i try to provision the ata through tftp all works fine.
If I try to set provisioning with http on the ata, in the syslog i found these messages:
Jul 23 07:25:55 SPA-3102 00: 0e:08:xx:xx:xx -- Requesting resync http://192.168.1.6:80/provisioning/web/spa.xml
Jul 23 07:25:55 FMM >>>> Requesting profile
Jul 23 07:25:55 create tcp connection failed
Jul 23 07:25:55 SPA-3102 00: 0e:08:xx:xx:xx -- Resync failed: http_get failed
Jul 23 07:25:55 FMM >>>> Failed profile
On the apache webserver logs there's no log of spa3102 connection. So i've done a tcpdump of data between ata and webserver and it seems that the ata have some trouble to open the socket (check the attached screenshot)
Hope someone can help me.
Bruno
nseto
Level 6
Level 6
Just wanted to verify, you are able to reach that file through your web browser?
i was able to solve this problem. My http server was running in a virtualized environment (Debian Lenny 64bit under VirtualBox): the VM's tcpip stack seems to be the problem. If I run the http server on a real machine the http provisioning works great.
Thank You
