07-23-2010 02:46 AM - edited 03-06-2019 12:09 PM
Hello all,
Do you know if the switch WS-C2960-48TS-S will be supported soon by the Network Assistant software ?
Tank you for your response.
Best regards
07-23-2010 02:56 AM
Hello all,
Best regards
Both Cisco Catalyst 2960 LAN Base and LAN Lite Switches support the following capabilities:
• Network management tool support by CiscoWorks, Cisco Network Assistant, and Catalyst Device Manager.
Hope to Help !!
Ganesh.H
07-23-2010 03:02 AM
i just installed 2x cisco C2960S-24TS-L (LAN Base Switch) and configured as a stack
when i detect this with CNA5.5 it tells me that it is an unsupported device.
i find this very odd as the documentation and all the download links point to CNA 5.5
regards
07-23-2010 03:46 AM
Same for WS-C2960-48TS-S, Network Assistant said that the equipment is not supported.
Therefore, I wonder if the care is provided in the roadmap
08-05-2010 10:09 AM
I'm having the same problem. A fix would be nice.
08-05-2010 10:35 AM
CNA support for 2960S is expected to be in version 5.6, tentatively scheduled for later this year. Hope this helps.
09-16-2010 04:31 PM
Cisco has introduced several new switches and didn't upgrade CNA to support them. I had to open a ticket with Cisco to find this out. Disappointing that Cisco can't even create a tech note to explain this. Apparently 5.6 which is beta will support these new switches. How about Cisco introducing the new CNA when the new switches come out?
10-20-2010 04:40 AM
Hi All,
Also I have had the same issue, and raised a ticket with Cisco. It took the tech a few days to come with the final answer!
The C2960S devices will be supported in CNA5.6, but the release is postponed untill 2011!!!
Also, since a few weeks, my switches (mainly the C3750's) started to have memory errors causing me not able to logon, not even by console cable.
Seems the http-server setting in combination with my IOS is causing the problems, and the only way to solve is to disable the http-server and a power cycle, resulting in the fact I'm unable to use CNA for part of my network......
Anyone else have the same issue?
Quirijn
08-18-2011 01:49 AM
No I have not had problem with my 3750's
However the CNA 5.6(3) still cannot see my brand new WS-C2960CG-8TC-L. Wenn will that be solved ? (Can someone from Cisco answer ? )
David
09-12-2011 10:34 AM
I also have this problem. It is very poor that CNA is not compatible with this switch.
Daniel
09-14-2012 03:38 AM
I had the problem in a similar machine, and since new version of CNA (5.8) is working OK.
