block vrrp multicast
Answered Question
Jul 23rd, 2010
We connected new VPLS L2 lines (whereas before we linked our site up with a L3 MPLS connections) for our sites to our datacentre (redundant 6500 switches).
Each site is in a separate vlan and the VPLS connections are connected on a single port as a trunk.
I've configured new VLANs and vlan interfaces with vrrp, but I see a lot af vrrp multicast traffic sent to the sites.
Is there a way to configure vrrp to only send its advertisements on a specific interface or to block vrrp on an interface?
Multicast has a tendancy to end up where you don't want it do - it does not do any harm, unless there is a device wanting to listen.
If you want to block vrrp multicast on a router the specific address is 224.0.0.18
A simple acl like:-
access-list 101 deny ip 224.0.0.18 any
access-list 101 deny ip any 224.0.0.18
access-list 101 permit ip any any
interface <>
ip access-group 101 out
Should do the trick...
For a switch -  much easier, just use:-
interface <>
switchport block multicast
HTH>
Overall Rating: 5 (2 ratings)
Correct Answer
A simple acl like:-
interface <>
interface <>
HTH>
Related Content
