ISP changeover/NAT and routing
Jul 23rd, 2010
I wonder if anyone can assist:
We are changing ISP, and for a short period have two lines, each with a 2811.   We use NAT translating a number of IP addresses onto one internally addressed web server. Unfortunatly I can't transition all the sites to the new IP address range at the same time. This means I can't change the gateway address an the web server without cutting off half the web sites.
On the old ISP at least, BGP is out of the question.
It has been suggested that traffic coming down the old ISP line could be tunneled to the new router, but then default routes don't allow for the return route through the tunnel as far as I can see/
Is there a way to allow for NAT traffic via two lines and two routers to one server?   I wonder if somhow nat outside can be used.
I'm sure this must be a fairly common issue!  What is the best way to solve it?
Nagaraja Thanthry Fri, 07/23/2010 - 08:02
Do you have control over both routers? If you do, then you can configure
route-maps and nat overloading such that all requests coming from the old
ISP seems like is coming from the routers inside interface. This way, when
the webserver is serving pages for those requests, it will send the response
back to the ISP1 router which is on the same subnet and not worry about the
default gateway. However, one change that you do need to do is configure NAT
on a virtual interface on the old ISP router.
Step 1:
Remove all existing NAT rules
Step 2:
On both outside and inside interface, enable NAT
Interface fa 0/0
ip nat enable
Interface fa 0/1
ip nat enable
Step 3:
Reconfigure all NAT rules
Step 4:
Configure an access-list matching http traffic destined to your webserver
Access-list 199 permit tcp any host overload
This should address your issue.
Hope this helps.
timhavenhand Fri, 07/23/2010 - 08:09
Thanks, that looks very helpful, though I'm not entirely sure I follow the bit about configuring NAT on a virtual interface.  But seems like that is what I should invesigate.
Related Content
