New to 5510
Jul 23rd, 2010
I would like some help please.
We have purchased a 5510 and I am new to this piece of equipment and need some help.
I have found a lot of information but they seem to mostly use the commend line and I am using the ASDM to configure my information.  I just want a connetion from the inside to outside using PAT and then allowing outside traffic in.
I know it shouldn't be that difficult but I don't have a lot of time to devote to configuring this equipment and there is no one else to do it.
I would appreciate any assistance that anyone could provide.
Joshua Engels Fri, 07/23/2010 - 06:48
Hi Katie,
What version of software is currently loaded?  8.2, 8.3 etc?  From the CLI, do a "sho ver"
you'll see a line like this...Cisco Adaptive Security Appliance Software Version 8.3(1)
katiehazlett7 Fri, 07/23/2010 - 07:01
Sorry I should have added that 8.3 is what I am using.
Thank you
Joshua Engels Fri, 07/23/2010 - 07:10
Here are the CLI commands.  Just substitue your inside network address scheme in place of 192.168.1.0 255.255.255.0.
If you have already setup your outside and inside interfaces this should work:  If you have not setup those interfaces, that will need to be done first.
object network my-inside-network
subnet 192.168.1.0 255.255.255.0
nat (inside,outside) dynamic interface
Also, here are the links to the ASA config Guide for 8.3 for ASDM and CLI:
http://www.cisco.com/en/US/docs/security/asa/asa83/asdm63/configuration_guide/config.html
http://www.cisco.com/en/US/docs/security/asa/asa83/configuration/guide/config.html
katiehazlett7 Fri, 07/23/2010 - 07:21
Thank you so much, I will try that out.
I do appreciate your assistance.
Joshua Engels Fri, 07/23/2010 - 07:03
Note on the guides that jathaval posted:  Make sure that your versions line up.  8.0 vs 8.3 etc.  Things will be similar between guides but you want to be aware if you are working between guide version and OS/ASDM version.  Slight differences etc.
katiehazlett7 Fri, 08/20/2010 - 13:34
Just to let you know this did not work for me.  I am not getting out.
Kate
Nagaraja Thanthry Fri, 08/20/2010 - 13:41
  • Cisco Employee,
Please try the following:
Assume that your inside network is 192.168.1.0/24. Your outside IP is 100.1.1.2 with ISP gw of 100.1.1.1
interface eth 0/0
nameif outside
security-level 0
ip address 100.1.1.2 255.255.255.0
exit
interface eth 0/1
nameif inside
security-level 100
exit
route outside 0.0.0.0 0.0.0.0 100.1.1.1
object network LAN
nat (inside,outside) source dynamic any interface
Please replace the sample IP addresses with actual IP's of your network.
Hope this helps.
NT
