necesito comparar la performance y cpu process de router...
Answered Question
Jul 23rd, 2010
Buenos dias.
Estamos por comprar router core para nuestro centro de computo:
(we are going to buy routers for our computer center):
Can you tell us with is the performance and the type of processor fo the following routers?
(pueden decirnos cual es el desempeño y el tipo de procesador de los siguientes routers?
2801
2811
2821
2911
2921
Agradeciendo anticipadamente a todos.
(thanking you in advance)
Attentively
(atentamente.
Correct Answer by Brandon Lynch about 6 years 7 months ago
Hey Roger,
As far as the 2800s go, here is a base breakdown of what these routers are rated for with full features enabled and IMIX traffic through them -
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/prod_qas0900aecd80169bd6.html
For full reports, you can check Miercom's website -
www.miercom.com
To get to these, simply click on 'Reports' at the top and then select 'Cisco Systems, Inc.' for the vendor and 'All' for the timeframe.  They have published full reports for most of the 2800 ISRs and the 2900 ISR G2s.  This should give you a good baseline for comparison purposes.  Hope this helps.
Brandon
Overall Rating: 5 (1 ratings)
Correct Answer
Brandon Lynch Mon, 07/26/2010 - 10:55
Hey Roger,
www.miercom.com
Brandon
