Banner on ASA 5520
Answered Question
Jul 23rd, 2010
I wanted to know if anyone can tell me what is the command that will allow me to copy and paste a banner statement on my ASA.
I'm trying to put the same banner on the ASA as my routers and switches. when i enter config mode and type banner login and
try to paste the banner i get errors but if i just enter one line something like, This is a restricted system it works, I just can't
copy and paste the entire banner in.
Correct Answer by JORGE RODRIGUEZ about 6 years 9 months ago
Reading the guidelines on banners for firewalls  it states.
quote from link bellow
"Multiple lines in a banner are handled by entering a new banner command for each line that you wish to add. Each line is then appended to the end of the existing banner "
Reference this link on  some basic  guidelines on banner usage in asa's
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/b.html#wp1355378
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Fri, 07/23/2010 - 13:01
  • Green, 3000 points or more
scooter817 Fri, 07/23/2010 - 13:30
Thanks a lot, i just applied the banner to the ASA's and the commands worked perfect
