Having problems with static route.
Answered Question
Jul 23rd, 2010
A picture of my network is attached. The instructions follows the HQ router config.
I am trying to set up two static routes on HQ router for B1 network and B2 network. Due to the IP address schemes I am assuming I would need to do two Summary Routes.
HQ Config:
Current configuration : 868 bytes
version 12.3
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname HQ
enable secret 5 $1$mERr$9cTjUIEqNGurQiFU.ZeCi1
no ip domain-lookup
interface FastEthernet0/0
ip address 192.168.64.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.65.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0
ip address 10.0.0.1 255.255.255.252
clock rate 64000
interface Serial0/0/1
ip address 10.0.0.5 255.255.255.252
clock rate 64000
interface Vlan1
no ip address
shutdown
ip classless
ip route 192.168.0.0 255.255.252.0 10.0.0.6
ip route 172.0.0.0 255.252.0.0 10.0.0.2
banner motd ^C** Authorized users only.**^C
line con 0
password cisco
login
line vty 0 4
password cisco
login
end
Here are the instructions that were given to me to do the lab:
Introduction:
This activity focuses on basic device configurations and static routing. The addressing scheme has already been determined. Once you have configured all devices, you will test for end-to-end connectivity and examine your configuration.
Learning Objectives:
  • Cable the devices.
  • Apply a basic configuration to the devices.
  • Configure static and default routing.
  • Test connectivity and examine the configuration.
Task 1: Cable the devices.
Cable the networks according to the topology taking care that interfaces match the labels shown in the activity. HQ is the DCE side of both WAN links.
Task 2: Apply a basic configuration.
Configure the routers with basic configurations including addressing.
  • For the WAN links, assign the first address to HQ and the second address to the other router
  • For the LANs, assign the first address to the router interface and the .10 address to the PCs.
  • Use cisco as the line passwords and class as the secret password.
  • Use 64000 as the clock rate.
Task 3: Configure static and default routing
  • HQ should have exactly two static route.
  • B1 and B2 should have one default route.
Task 4: Test connectivity and examine the configuration.
Step 1 – Test connectivity.
  • You should now have end-to-end connectivity. Use ping to test connectivity across the network
  • Troubleshoot until pings are successful.
Step 2 – Examine the configuration.
Use verification commands to make sure your configurations are complete.
Correct Answer by Jon Marshall about 6 years 10 months ago
jdbaby0504 wrote:
I can not ping from network to network but I can ping to directly connected interfaces. I am summarizing on HQ router.
I am trying to summarize the networks:
172.24.0.0
172.25.0.0
172.26.0.0
172.27.0.0
I am using command
I am slo trying to summarize the networks:
192.168.0.0
192.168.1.0
192.168.2.0
192.168.3.0
I am using command
Okay -
172.0.0.0 255.252.0.0 =
172.0.0.0
172.1.0.0
172.2.0.0
172.3.0.0
so you need to use
172.24.0.0 255.252.0.0
Your 192.168.0.0  255.255.252.0 summary is correct.
So is it anything you can't ping or just the 172.x.x.x networks ?
Jon
Overall Rating: 5 (1 ratings)
Jon Marshall Fri, 07/23/2010 - 11:41
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
What is your actual question ? Are you saying after entering the static routes at HQ you cannot ping anything ?
Jon
jdbaby0504 Fri, 07/23/2010 - 11:56
172.24.0.0
172.25.0.0
172.26.0.0
172.27.0.0
I am using command
192.168.0.0
192.168.1.0
192.168.2.0
192.168.3.0
I am using command
Correct Answer
Jon Marshall Fri, 07/23/2010 - 12:04
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
172.24.0.0
172.25.0.0
172.26.0.0
172.27.0.0
I am using command
192.168.0.0
192.168.1.0
192.168.2.0
192.168.3.0
I am using command
Okay -
172.0.0.0
172.1.0.0
172.2.0.0
172.3.0.0
so you need to use
Jon
jdbaby0504 Fri, 07/23/2010 - 12:11
Thanks Jon that worked perfectly. Just one question can you direct me to where I can get more info on route summarization?
Jon Marshall Fri, 07/23/2010 - 12:31
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Glad to help and thanks for rating.
Not sure where to go to be honest. I'll have a hunt around. When you summarise you can do it with binary but after a while it becomes easier to work it out in your head ie. in your example -
172.24
172.25
172.26
172.27
so you want to summarise the above 4 networks. We'll do it in the steps i took -
1) You need to summarise 4 networks. The first network is 172.24. Is 24 a multiple of 4 = yes.
2) Because 24 is a multiple of 4 you know that you can start with 172.24. and cover the next 3 network ie. 25,26,27
3) To get the actual subnet mask for 4 networks - 256 - 4 = 252. So the 2nd octet is 252
Lets assume another example to show how it doesn't always work as neatly. You want to summarise in one statement -
172.22
172.23
172.24
172.25
Using the same steps above -
1) 22 is not a multiple of 4. So you know that you cannot summarise this with a 252 subnet mask.
2) What is the next subnet mask up from 252 which covers 4 networks. It is 248 which covers 8 networks ie. 256 - 248 = 8
3) Will an 248 subnet mask work. Well if you go up in 8's it goes networks 0 -7 , 8 - 15 , 16  - 23 , 24 - 31, 32 - 39 etc.
4) Looking at the 4 networks you are summarising even that won't work because the 4 networks do not fit into one of the above ranges provided for by a 248 mask.
5) next subnet mask up is 240. 256 - 240 provides 16 networks. So your ranges are 0 - 15, 16 - 31, 32 - 47 etc..
6) So you can see that now the 4 networks fit in the range  16 - 31.
So 172.16.0.0 255.240.0.0 would cover your networks but it's important to realise you also cover a lot more networks ie. 172.16 - 21 & 172.26 - 31 are also included.
Note that i said it should be summarised in one statement. If you were prepared to use 2 you could do -
172.22.0.0 255.254.0.0
172.24.0.0 255.254.0.0
the reason i used one statement was i wanted to point out that just because you have 4 networks to summarise doesn't necessarily mean you can always just assume a 252 subnet mask.
Thats how i do it in my head. Hopefully that has helped although if it has confused you more i apologize.
Jon
jdbaby0504 Fri, 07/23/2010 - 12:48
Thanks for the info I will definitely put it to use.
