Change HDS that Archiver is pointing to
Jul 23rd, 2010
What is the correct process to change the HDS that the archiver is pointing to to pull data.  I see that the linked server connection adds an entry to the t_connection database on the archiver.  would the best procedure be to re-run the CUIS setup program to change this, or what i would like to do which is to just change the info in this table by updating the hostname and ipaddress?
hiteshpa Fri, 07/23/2010 - 14:13
  • Cisco Employee,
You will need to run the CUIS configuration tool again to change the HDS. The tool is located at C:\Cisco\CUIS\bin\CuisConfigTool and it s called CuisConfigTool.exe.
Please refer to the Archiver user guide for more details.
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/intelligence_suite/intelligence_suite_75/user/guide/isa75ug.pdf
Hope this helps.
Hitesh
