7916 Expansion Module not displaying lines.
Answered Question
Jul 23rd, 2010
I have a UCM (7.1.3) server; 7965 Phones; and 7916 Expansion Module. The problem I have is the expansion module will not display line text information. I look under device defaults for the phones and show SCCP45.8.5.3S as the load. What do I need to do to make this work?
Correct Answer by david-lima about 6 years 10 months ago
Hi, if you want to upgrade  the firmware of an individual iIP Phone, check this post:
https://supportforums.cisco.com/message/3003486#3003486
I tried that and work fine.
Just take note of the Phone Load Name in the Device > Device Settings > Device Defaults.
hth
David
Overall Rating: 5 (1 ratings)
Adrian Saavedra Fri, 07/23/2010 - 15:31
  • Gold, 750 points or more
Sorry if this might sound pretty obvious: Do you already configured the 7916 under Expansion Module Information in the 7965 configuration page?
Kind regards,
- Adrian.
kmusgraves Fri, 07/23/2010 - 16:30
Yes, everything is configured on the phone. I have some newer phones that work right out box and these have been on the shelf for a year or more and don't work. I think the firmware needs upgrading but I don't know the how to do that for individual phones.
kusatija Sun, 07/25/2010 - 02:00
  • Silver, 250 points or more
hey, i don think the firmware should be the problem, if the phone has actually taken that firmware..
Could you chek if you have configured the phone button template on the phone correctly, by going to device>>device settings>>phone button template?
Also check if the phone actually got the firmware you mentioned, by either checking the application load id on the phone physically or browsing the IP address of the phone.
Kunal
