IOS ver recommendations for WCCP
ogencheva
Can anyone comment on recommended IOS versions for software based routers (7206VXR) for WCCP? I am looking at the table that suggests the following versions - 12.1(14); 12.2(26); 12.3(13);12.4(10); 12.1(3)T; 12.2(14)T; 12.3(14)T5;12.4(15)T8;15.0(1)M. Is it a minimum code or recommended code? My router is running 12.3(23), which is a GD version and the latest version for 12.3 train is 12.3(26).
Thanks.
nchidamb
Cisco started support WCCPv2 on 7200 router series since 12.0(5)T.  So, yes, those are minimum recommended IOS versions from WCCP perspective.
Nat
