Trunk
Jul 24th, 2010
We got Cisco 3825 running 12.4 IOS, it functions CME.
There is a SIP trunk between Cisco CME and Nortel for outgoing calls.
I need to understand
* If there is limitation on SIP Trunks or router hardware
* Command to see how many active calls
* Command to see max call limit
Marwan ALshawi Sat, 07/24/2010 - 06:08
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
fir of all i would recommned you to post your question in the voice and ip telphney section of Netpro
anyway as long as you are using SIP trunk ( max call depends on the voice codec you are suing and the bandwith you have )
try show vocie call active summry
