TCP Probe on ACE 4710
Jul 24th, 2010
I am trying to configure proble on ACE device and I have few queries on those:
1. I want to probe 10 different tcp ports for a serverfarm, is there any way i can give the range on probe ? if not and if i have to probe individual port and then configure in a serverfarm, how it would behave i.e. I want to fail the probe only when all the configured ports are failed.
2. I am trying to configure probe for a particular tcp port, but I suppose server is not sending RST to that port, so probe is failing. However if I try to telnet that port from any other location it is getting connected. How can I configure probe in that case for that port ?
Pls. suggest.
Pawan
winpwnkmr Mon, 07/26/2010 - 00:25
Thanks Gilles, Could you pls. suggest on my 2nd query too ?
Thanks.
Gilles Dufour Mon, 07/26/2010 - 02:24
  • Cisco Employee,
You should sniff the traffic ...if the probe is down it means the server did not respond to our SYN.
We do not expect a RST.
Gilles.
