Cisco 2811 VPN
Answered Question
Jul 24th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;}
I have a Cisco 2811 Router with 3 ADSL WAN Wic’s.
I have a number of remote sites that I want to setup via a site to site VPN link. Setting this up via the first WIC or other WIC is no problem however when I setup a number of sites to use the first WIC and proceed to setup additional sites using the second or third WIC I keep getting phase one errors.
As soon as I reconfigure my remote router with the peer address of the first WIC on the 2811 it connects without any problems.
Any suggestions please.
Correct Answer by Federico Coto F... about 6 years 8 months ago
Peter,
Might be a bug?
You should not have any problem regarding the amount of VPN tunnels configured (as long as it is supported by the router).
For example,
For the router should be exactly the same having a single tunnel terminating or 10 tunnels on either WIC.
Which IOS are you running.
Federico.
Overall Rating: 5 (2 ratings)
Correct Answer
Federico Coto F... Sat, 07/24/2010 - 16:59
  • Green, 3000 points or more
Peter,
Might be a bug?
For example,
Federico.
peterv Sun, 07/25/2010 - 14:53
Hi Federico
Thanks for the response, see below router IOS versions.
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(24)T3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 23-Mar-10 06:43 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
system uptime is 10 weeks, 6 days, 10 hours, 10 minutes
System image file is "flash:c2800nm-advipservicesk9-mz.124-24.T3.bin"
I agree it should not make any difference, I just can't figure out why I should get phase one errors just because I am setting up aditional VPN's on the second WIC or Third WIC
