CM 4.2(3) to 7.1(5) License Transfer
Answered Question
Jul 24th, 2010
Can someone please guide me on how to transfer phone license (DLUs) from exisitng 4.2 to new 7.1?
We purchased node and sw license for new call manager. We have approx 300 phones (all licenses). 250 of them are registered. 50 are not.
Is there a way on CM 4.2 to get a list of what licenses are installed? I am really confused with this license thing.
I don't want to go to cisco TAC and sound stupid.
Please any pointers/help is really appreciated.
OJ
Correct Answer by Jaime Valencia about 6 years 6 months ago
Well, you NEED to reach our licensing team at TAC one way or the other.
Write them down an email ([email protected]) explaining you need to migrate some licenses and provide them the MAC from new server.
You'll get a spreadsheet they'll use to generate the necessary .lic files.
They'll let you know any other info they might need.
The other way is if you're still to do the migration DMA will do this process and you'll just need to change the temp license into a permanent license.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Sat, 07/24/2010 - 15:06
java
Ojasvi Bansal Sat, 07/24/2010 - 18:50
Thanks Java
Thats the kind of information I was looking.
Appreciate your response.
OJ
