UCCX IVR script to play 2 different MOH on Re-direct Transfer
Jul 25th, 2010
Hi Guys,
The is for an Autoattendant script.
I have the question from client to prepare the script that will play 2 differnt MOH after  Menu selection.
The Script call flow is
1. Incoming call from PSTN to Pilot no.
2. Welcome message with Selection option 1 for Local language & 2 for English.
3. Under Local language Menu there a differnt Prompt & sub menus options
4. When the call is transfered to sub menu call re-direct No it should play MOH in the local language.
If the users selects 2 for English
then under sub menu after call -redirect option to Extn it should play English MOH.
The MOH is played from CCM CTI ports now.
How do i play different MOH for 2 different menus.
DO you guys have different thinking to make this work.
James Hawkins Sun, 07/25/2010 - 13:27
You could define three applications
  1. Language choice
  2. Local Language
  3. English Language
and use different CTI ports for 2 and 3 with different MoH sources.
You would call 2 and 3 from 1 using the Trigger Application step.
Should work although I must admit I have not tried this myself.
Jonathan Schulenberg Mon, 07/26/2010 - 05:26
James' method is the preferred one if you are on 7.0(1)SR5 or later. Prior to that the Trigger Application step in synchronous mode had a nasty JTAPI defect on it CSCtd72562.
If you have not cleared that defect, you would need to do a Call Redirect between the CCX application triggers.
