07-25-2010 06:35 AM
Does anyone has an EEM script which can bring down the interface when it sees a ospf neighbor failure
thanks
Ambi
07-25-2010 02:27 PM
A simple applet should do the trick:
event manager applet ospf-watch
event syslog pattern "OSPF-5-ADJCHG.* to DOWN"
action 1.0 cli command "enable"
action 2.0 cli command "config t"
action 3.0 cli command "interface gi0/1"
action 4.0 cli command "shut"
action 5.0 cli command "end"
07-26-2010 11:51 AM
Thanks Joe .. that worked perfectly fine
However can we do an or operation on the event .. meaning bring down the interface if the ospf is down or goes to Init ??
Ambi
07-26-2010 11:55 AM
You can adjust the regexp to match other OSPF states:
event syslog pattern "OSPF-5-ADJCHG.* to (INIT|DOWN)"
07-26-2010 12:49 PM
Can we have 2 event manager applet like below ... it doesnt seem to work though for me
event manager applet ospf-watch-down
event syslog pattern "OSPF-5-ADJCHG.* to (INIT|FULL)"
action 3.0 cli command "interface fa 1/15"
event manager applet ospf-watch-up
event syslog pattern "OSPF-5-ADJCHG.* to UP"
action 4.0 cli command "no shut"
Also getting folowing error with just the first applet in the configuration
*Mar 1 00:23:31.347: %OSPF-5-ADJCHG: Process 1, Nbr 1.1.1.2 on Vlan200 from FULL to INIT, 1-Way.!
*Mar 1 00:23:31.375: %HA_EM-3-FMPD_CLI_CONNECT: Unable to establish CLI session: no tty lines available, minimum of 2 required by EEM
*Mar 1 00:23:31.375: %HA_EM-3-FMPD_ERROR: Error executing applet ospf-watch-down statement
Ambi
07-26-2010 12:56 PM
Your second policy would have to check for a state transition to FULL:
event syslog pattern "OSPF-5-ADJCHG.* to FULL"
As for the error you're seeing, this is due to you being out of free VTY lines. EEM requires at least two free lines to run CLI commands.
07-26-2010 01:18 PM
Thanks for correcting but for some reason EEM doesnt seem to be working
SW1#sh event manager policy registered
No. Class Type Event Type Trap Time Registered Name
1 applet user syslog Off Fri Mar 1 00:50:56 2002 ospf-watch
pattern {OSPF-5-ADJCHG: Process 1, Nbr 1.1.1.2 on Vlan200 from FULL to INIT, 1-Way}
action 3.0 cli command "interface FastEthernet1/15"
SW1#
SW1#
SW1#
*Mar 1 00:55:42.575: %OSPF-5-ADJCHG: Process 1, Nbr 1.1.1.2 on Vlan200 from FULL to INIT, 1-Way
SW1#
SW1#sh use
SW1#sh users
Line User Host(s) Idle Location
* 0 con 0 idle 00:00:00
98 vty 0 idle 00:00:14 EEM:ospf-watch
Interface User Mode Idle Peer Address
SW1#
Lines ae free but the syslog message didnt trigger the interface shutdown :-(
Ambi
07-26-2010 10:08 PM
If you are using AAA command authorization, make sure you configure the following:
event manager session cli username USER
Where USER is a user authorized to run all of the CLI commands in your EEM policies.
