Unable access VoiceMail box
Answered Question
Jul 25th, 2010
Hi Team,
I am installing Cisco Unity 7.1.2.10000-139 in Our Lab (VMWare environment with Athlon Processor). Installation & integration has been done successfully, but I am facing the following issue while trying to access the Voice Mail Box:
1. After pressing message key, " Prompting enter your PIN no ". After putting the PIN, I found silence for while and phone display showing "Temp Fail"
Then I unable acess the Unity for while.
2. Call Handler is working fine.
Please help me on this regards,
Note: I am using Demo License.
Nirmal
Correct Answer by David Hailey about 6 years 11 months ago
I just went thru a similar thread on this exact topic a week or so ago.  In fact, it turned out the circumstances are the same.  If you look thru the forums and Google as well then you'll find that the primary issue you're running into is that the UC apps don't perform too well and/or have known issues running on AMD processors with VMWare.  Same installs with Intel processors typically do not have issues.
Hailey
Please rate helpful posts!
Overall Rating: 5 (1 ratings)
Nirmal Paria Sun, 07/25/2010 - 06:51
Please ignore my previous post.
Hi Team,
I am installing Cisco Unity Connection  7.1.2.10000-139 in Our Lab (VMWare environment with Athlon Processor). Installation & integration has been done successfully, but I am facing the following issue while trying to access the Voice Mail Box:
Nirmal
Martin Skovsoe Mon, 07/26/2010 - 05:37
Hi Nirmal
I would check the codecs between callhandler and CUC!
/Martin
Nirmal Paria Mon, 07/26/2010 - 07:38
Hi Martin,
Thanks for your quick response..
I did not define any codec. All are using default codec. No region configured in CUCM.
regards,
Nirmal
markhayek Mon, 07/26/2010 - 08:45
When you get Temp fail, it looks like the CUCM lost its connection to the phone and went to SRST mode.
In SRST mode, you may not be configured to use Unity.  Find out why the phone is losing conenction to the CUCM first.
Correct Answer
David Hailey Mon, 07/26/2010 - 10:30
  • Purple, 4500 points or more
Hailey
Nirmal Paria Mon, 07/26/2010 - 19:53
Haily.. Thanks for your response.. I also found the same yesterday.. Let we investigate more and try to find out the solution.
Nirmal
