SPA3102 Dialing Delay
Jul 25th, 2010
I've got a SPA3102 connected to both the PSTN and SIP provider. All is working fine apart from a few little niggles.
Whenever I dial out on the PSTN, it takes about 10 seconds to start hearing the ringing at the other end. Is this the 'PSTN Dialing Delay' setting that needs to be changed. Its currently showing as 1, or is there something else, or indeed, is this how it should be?
Alberto Montilla Tue, 08/10/2010 - 02:07
Dear Robert;
This is likely related to the dial plan. The interdigit long timer delay applies when the dial plan entry is too generic. Options:
- Set the interdigit long timer delay to a shorted number (default is 10, dont recommend anything lower than 5 for this)
- Change the dial plan to include more explicit entry to dial through PSTN.
