AIP-20 Vs 4255- Recomended Solution?
Answered Question
Jul 25th, 2010
Hello experts,
We have 5510 ASA pair (Active/stdby) at the perimeter. For implementing IPS solution, wondering if 4255 is is recomended or AIP-20 SSM modules in ASA5510 would be our better bet. Future internet  growth- tops 200Meg (dual 100Meg pipes)
TIA
MS
Correct Answer by rhermes about 6 years 7 months ago
I the ethernet interface on the AIP-SSM modules can only be used for management interface access.
The internal access via the ASA does not allow for the webgui access or event flows, only CLI access.
- Bob
Overall Rating: 5 (1 ratings)
rhermes Mon, 07/26/2010 - 10:03
It depends on a few things.
Do you want to do in-line IPS or Promiscious mode IDS?
What is the expected traffic volume to be passing thru these sensors?
What you want to be careful about is place a single sensor in-line with dual firewalls. This thread explanes why:
https://supportforums.cisco.com/thread/2032810?tstart=0
The 4255 has twice the processing power of the AIP-SSM20, meaning it can handle twice the traffic. If you are doing promisicous mode detection, a single sensor will be easier to maintain.
- Bob
mvsheik123 Mon, 07/26/2010 - 10:43
Hi Bob,
Thanks for taking my quesry again. The other thread was when I thought of adding a 4255 but later few cisco tech mentioned better to go with AIP module- hence the new thread..;-).
We want to start prmiscous mode (that way we can understand/study the traffic) , then move to in-line. Does AIPs support this way?
If I decide finally with 4255, then I may ended up in buying 2 (if place in-line).
After all the user traffic rerouted to single location, anticipated usage 50-60Meg. Also, we may have upto 200 Meg internet (2x100).
TIA
MS
rhermes Mon, 07/26/2010 - 13:26
Yes the AIP-SSM modules support both in-line IPS and Promiscious mode IDS.
- Bob
mvsheik123 Mon, 07/26/2010 - 13:59
Thanks again Bob. Also, the port on AIP modules, this is purely for management kind or its a gig (10/100/1000) that can be used as additional port on ASA (ex: DMZ2 etc).
MS
Correct Answer
rhermes Mon, 07/26/2010 - 14:10
- Bob
