Call Manager 4 - CDR are automatically purged
Jul 25th, 2010
I have an issue with a CM4.0 Call Detail Records. I have set the Automatic Purge to delete records that are older than 60 days. However, when I query the SQL database and check CDR from GUI, the oldest record available is only 30 days ago. Any records older than 30 days seemed to be automatically deleted.
Did I miss some parameters that I need to set?
William
rynard.coetzee Mon, 07/26/2010 - 03:30
Not sure but you might have a high water mark set for disk space ,so it will keep CDR`s for 60 days or untill the high water mark is reached ,whichever comes first
rynard.coetzee Mon, 07/26/2010 - 23:11
Can`t remember anymore .. i will scratch around and see if i can find any links on the net. If my memory serves me ,i think it was in the SQL DB Admin somewhere ... Will let you know
rynard.coetzee Mon, 07/26/2010 - 23:30
Have you set the Max CDR Records Value under Service Parameters ,Cisco Database Layer Monitor ?
