LMS upgrade from 3.0 to 3.2
ikbalc
I am using LMS 3.0 and would like to upgarde this to latest version(3.2).How will I get the software? .Is it downloadable? if yes please share the link
Need to get the full LMS 3.2 version or upgrade software from 3.0 to 3.2.I am not sure whether both software are same or not.
Do i need to purchase new license ?
what is the procedure of upgradation ?
As I said, if you upgrade a licensed copy of LMS 3.x to the downloaded 3.2, you will end up with a permantly licensed copy of LMS 3.2.  The 90-day eval only applies to those who do not have an LMS 3.x license.
Joe Clarke
You can download LMS 3.2 from http://www.cisco.com/go/lms .  The download says it's an eval, but as long as you have an LMS 3.x license, you can upgrade your current copy of LMS to a fully licensed copy of 3.2.  The upgrade instructions can be found at http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/install/guide1/instl.html .
Thanks clarke,
I have got this link already.but this software is having the validity for 90 days.What is the procedure to get the permanent one?
Ikbal C
Hi Clarke,
Thanks for the information.
