can the 802.1x use the local database for authentication?
Jul 26th, 2010
i use "aaa authentication 802.1x default local" ,but it not succeed.
Sebastian Helmer Sun, 08/01/2010 - 02:42
I hope that helps you.
Configuring Access Points or  Routers to Use the Local Authentication Server
If your local authentication  server access point also serves client devices, you must configure the  local authentication server to use itself to authenticate client  devices.
On the wireless devices that use the local authentication server, use  the radius-server  host command in privileged EXEC mode to enter the local  authentication server as a RADIUS server. The order in which the devices  attempt to use the servers matches the order in which you enter the  servers in the device configuration. If you are configuring the device  to use a RADIUS server for the first time, enter the main RADIUS servers  first, and enter the local authentication server last.
best regards,
