IPSEC throughput of 1841 & 2811
I really need to know if anyone have tested the 1841 & 2811 routers for IPSEC VPN performance.
Some other real world tests shows much lower numbers.
I've seen documents from cisco stating...
45Mbit/s for 1841
95Mbit/s for 1841 with AIM
55Mbit for 2811
130Mbit/s for 2811 with AIM
nicholas_ong
Hi Marcus,
The positioning of the Cisco Routers are as follows
1841-1xT1/E1/xDSL,
2801-1xT1/E1/xDSL,
2811-2xT1/E1/xDSL,
2821-4xT1/E1/xDSL,
2851-6xT1/E1/xDSL,
3825 ½xT3/E3,
3845-1xT3/E3.
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/isr.pdf
My impression of the above is that the routers are designed to run with full feature sets at these levels.
The speed that you had listed are raw throughput speeds, so pending on features you are are running on the router, it may be significantly lower.
