SPAN 6500
jagdev.dhaliwal
Hi All,
I have configured the SPAN for 6500
with  following command
set span 107-110,301-350 1/2
in sh run it shows below one including other parameter which i did not set:-
set span 107-110,301-350 1/2 both inpkts disable learning enable multicast enable create
but when i check the status of  SPAN it shows following status :-
Destination     : Port 1/2
Admin Source    : VLAN 107-110,301-350
Oper Source     : None
Direction       : transmit/receive
Incoming Packets: disabled
Learning        : enabled
Multicast       : enabled
Filter          : -
Status          : inactive
Total local span sessions:  1
ANd the port stauts of destination is here
sh port 1/2
Port  Name                 Status     Vlan       Duplex Speed Type
1/2   IDS-02              notconnect 999          full  1000 1000BaseSX
Can you please check and let me know whether there is issue with my configuration for SPAN or it is inactive because the destination port is connected?
Thanks in anticipation
Jagdev
Viral Bhutta
Please refer to this link
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst6500/catos/8.x/configuration/guide/span.html#wp1033304
By default,
both->both receive and transmit traffic is captured
inpkts disable->disabled reception of the incoming packets from the device connected to destination port
learning enable->Learning is enabled
multicast enable ->Multicast packet monitoring is enabled
So set span 107-110,301-350 1/2 perfectly matches what you see in running configuration.
Span Session
When enabled, a SPAN session might become active or inactive based on various events or actions, and this would be indicated by a syslog message. The "Status" field in the show span and show rspan commands displays the operational status of a SPAN or RSPAN session.
A SPAN or RSPAN destination session remains inactive after system power up until the destination ports are operational. An RSPAN source session remains inactive until any of the source ports are operational or the RSPAN VLAN becomes active.
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst6500/catos/8.x/configuration/guide/span.html#wp1019851
Let me know if this helps
