Cisco 3G signal quality (Cisco 881G)
Jul 26th, 2010
I use as my backup for WAN sites the 3G+ network. I need your help in how to ensure a better performance or covergae continuity for my cellulars interafaces.
is it possible that the signal quality change from time to time ?
as my provider confirm a good signal the day of the installation but after the signal is not the same.
with the show cellular radio interafec, does someone can tell me which are the better performances of a good signal ? whitch range of -db ?
Thanks for your help,
AA
